Great news, sorry about the valve covers. Small setback I hope at this point. She is a beauty, and fierce looking.Drove it like 6 miles maybe. Still not confident to go too far from the house. No oil splatter. Turbos aren’t smoking. I think I solved the issue. I’ll have to check again and remove an oil return hose just to be sure. It’s really not that hard so I could frequently check.
Did a log for Brad finally. Back to the 1st revision and BBK TB. I had tried a second revision to see if we could raise idle rpm but it didn’t make any difference so I went back to the original tune.
Only issue it seems now is an oil leak on the rear valve cover, appears to be from under the PCV canister, closest to Firewall. Drips on my rear exhaust manifold. I’ll have to grab the bull by the horns and just remove the valve covers and replace all the seals and gaskets.
Was able to snap some pics out on my test drive View attachment 92522View attachment 92523View attachment 92524View attachment 92525View attachment 92526View attachment 92527View attachment 92528View attachment 92529View attachment 92530View attachment 92531View attachment 92532View attachment 92533View attachment 92534View attachment 92535View attachment 92536
Despite the bugs Ive been experiencing and slowly eliminating it really does feel fantastic what little mileage I’ve done. Still trouble shooting my Works Bell paddle shifters so in Drive the car quickly shifts and it feels effortless, smooth as butter. The exhaust fender exits are loud but somehow not as loud as I expected. Watching my boost gauge I don’t think I’ve done more than 3-4 psi and in lower rpm in 3rd gear mostly. It gets up to speed quickly. When I just did a log for Brad I moderately gave 3rd gear a 2500-4,000 rpm pull and looking down I’m going over 60 and I feel like the car is hardly trying. It felt like was going faster than it tried. The stance of the car feels so glued to the road, the massive 20x10.5 wheels, 305 wide tires and custom 2.5” spacers made to the cars hub bore and to the wheels hub bore, with new wheel bearings,axles….its so smooth, no vibration whatsoever. The all metal modified top trans mount makes it feel tight and crisp..it’s all connected so tight, as one.How does she feel Andrew? Give us a seat of pants review.
Unfortunately it’s supposed to snow today or definitely tomorrow so I think that time has come. Over the winter I plan to add the 2 piston rear calipers and Voodoo13 hydraulic hand brake, finish the exterior wrap, do something in the rear either another diffuser and/or add back the Lowe plastic trim, valve covers removed maybe just have the PCV canister ports deleted with block off plates welded and -10 AN for the VTA catch tank.Baby steps till you're absolutely sure it's all good. So amazing what you've accomplished. Soon you'll have to put her up for the winter again and that'll give you more time to check all the mods and be sure.
That’s what I’ve been waiting for!!!! Beastly!
Can't wait for a sound bite under WOT!That’s what I’ve been waiting for!!!! Beastly!
Go-Pro that beoch up - lolCan't wait for a sound bite under WOT!
dragon spitting fireBoy, you can hear them Turbos spooling now. That's how Ford should've done it to begin with.
S I N I S T E RLight revving sound clip
I can't wait for spring too, already planning a trip. The wife is in the know - we will check out the state - counting the months.I’ve been enjoying time off from doing anything to the car. I moved it again out of the garage lol that’s about it. Man I wish it was Spring! But I’ll be on the roads as early as late March, beginning of April. I think once it’s broken-in tuning will go quickly. Make it to the track when it opens and it’s still relatively cool out. I impulsively bought a Ford emblem at O’Reillys lol. Should I bring it back? View attachment 92788View attachment 92789View attachment 92790
Looks damn good, normally I debadge and black things out. With the rest blacked out the blue complements the blue Sparco tow strap.
I had a chance to see 2 different platforms showcase some performance results with Garrett G25-550 turbos in a twin turbo setup. Both are built motors. Both are sedans, 6 cylinder. 2001 Audi S4 ran 60-130 in 4.7 seconds! An Infiniti Q50 RWD ran 60-130 in 4.9 seconds! Even if my car runs 2 seconds slower for whatever reason…call it a Taurus handicap…LOL…my best 0-60 was a 3.18…have to be in the 2’s now. So even with a 2 second handicap my car should be capable of a 9.99….but I’m going to say it’s likely capable of more of a mid 9. Presumably running great….unless something breaks…I don’t see why it can’t.
I hate to guess too much but at some point, with all the modding and planning ….i really should be confident in the upgrades and parts. So I’m pretty pumped seeing those other 2 platforms have great success with my turbos. I’ve previously seen single turbo applications with them and ppl struggling to hit 500 whp, seems a single is good for about low to mid 400. Anyway, I think the car has a lot of potential and from seeing those results I’m a little more pumped to see how she does than before. Whatever happens, she won’t run out of turbo or fuel.
