shoclown
shoclown
okay i am looking for some feed back on the bbb system.
on a different post i stated a extreme power loss or feeling of one after complete 60 k.
Last night i pulled the front covers off and rechecked the cams and timing belt placement. it looks good but while i was looking at the timing belt i had the end tank with ign module. i looked into the intake and double checked the BBB to make sure they are able to open close etc.
i did not find any thing preventing them from opening/closing.
So are they normally open and when the recieve the signal to the elect switch it allows vacuum thru the close them?
i dont know why ut in my mind i thought the were normally closed and then they were opened at around 4k?
i am, so frustrated about know becouse i did a very thouragh 60 k vacuum hosess ign etc. then i replaced with BBB and acid ported the runners, cand l maf larger injectors , apexi zex kit y pipe and a bunch of other stuff only to make it lose its zip. i mean before it felt fast and now it doesnt. i have removed all the stuff except the oil catch can and returned it to stock except BBB and Ported runners. and its still does not feel fast as before.
the frustration is from obvious tear downs about a hundred it feels like... i have chipped the paint on the valve covers runners etc. so even after i figure out what went wrong i still have to tear it down and repaint it again...
any help ideas etc wiull be greatly appreciated.
