60 k question
RJ-92
Crappy NYS
Well, after reading Fred's post on that valve shim. I was wondering if I should check my clearence again soon. I had the 60K service done at 82K. I had talked to the mechanic and he said all of the clearences were within spec. I checked them again at ~90k because I had to replace the damn plug well gasgets. I hust looked at 2 or 3 of them real quick and they were OK but on the loose end of OK. It now has 109K and is in storage. Should I check them again before I drive her again in the spring or will it be OK for a while.
Ron Wazz
Red 92 mtx 106,000
ss y-pipe,
dynomax exahust w/open mufflers,
street/strip clutch,
lt. weight fly wheel,
ss tq limiters,
bored out MAF,
UDPs, ported intake
Konis and Eibachs
The shim and tappet failure that Fred found was a rare instance. The SHO's valvetrain is a fairly stout piece of machinery and requires only preventative maintenance to keep it running for a long time. The 60,000 mile adjustments are sufficient according to Yamaha and Ford. As long as the gaps were in the allowed range [added later] and you use a quality oil (no Pennzoil or Quaker State) and change it every 3,000 miles, your engine should be fine. The next time you go through all of the effort to get the valve covers off, it makes sense to set the gaps on the nominal setting rather than leave some at the ends of the range.
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
[This message has been edited by sdpatt (edited 12-03-2001).]
RJ-92
Crappy NYS
Scott,
Thank you much. I feel better.
Ron Wazz
Red 92 mtx 106,000
ss y-pipe,
ss tq limiters,
bored out MAF,
UDPs, ported intake
Konis and Eibachs
