RJ-92
Serious MTX issues
Driving home from the track tonight I was almost home and I went to shift into 5th and it was grinding a little as it went into gear. It wasn't overly difficult to get into 5th it just was grinding doing so. At first I thought it was me not being on the clutch enough, after a few more tires it was definately the gear. It only does it in 5th. THe TO bearing and clutch are new, as is the tranny, it has been recently rebuilt (~4k miles). All the other gears shift great, and 5th usually has too until tonight.
I have recently changed the fluid and I also have an issue with the shifter boss.I'll have to check them two out tomorrow. If they check out OK, and I believe they will, what else would cause grinding of 5th only???
*update* Now I have found I have no reverse either. I went to move the car so I could get it on some jack-stands to check it out and I would not go backwards. Reverse might as well be neutral.All forward gears engage but no reverse at all. Help, What's wrong with my Trany?
