312 hp 266TQ NA
jayro
Auburn, In
Installed 48# injectors so there are a few other things you have to take into the tune but really no harder than any other modded SHO. Clutch in and rolling I can still get some mad surging but I figure its just the nature of the beast it only as 10-12 inches mercury vac at 1100 idle.
Hmmm. Better start saving my pennies for some pistons.
gmail
Well-Known Member
sunbury pa
.375 lift on both cams 228 deg on Intake and 216 deg on Exhaust with 26 deg of over lap.
Cranking Comp was 210-215 psi.
basicly if shonut had offered plus 30 cams these would be it haha..
hows the idle with these cams?
Ishodu
Is rough. But I love it. It won't idle at all below 900. I have it set to 1100. And I had the vac gauge on today checking fuel pressure at was only getting only 10 in mercury at 1100 rpm
yamahaSHO
E85 whore
Arkansas
I idle at 1,200 now (was 1,150) and I only see 10 in/hg at idle with SS stage 1 cams (I imagine forcing air on the TB doesn't help).
If your idle is still rough, try a 13.5:1 - 13:1 mixture at idle. This cleared my idle up (hot over-lapping cams generally require more fuel to run smooth at idle)
Ishodu
Could likely play with injector timing as well so that not as much of the fuel is going out the tail pipes.
