3.2 timing components, pulleys, exhaust manifolds, heads, harness.
jimtash
nc
Building a 3.2L conversion and have many parts that aren't being used. I'll post more as time permits but here is what's for sale so far.
Update:
Oil pan, DPFE, IAC, and coil are sold.
SSPX0042
Timing belt tensioner $30.00. sold
Idler pulley $10.00 sold
Water pump pulley $10.00 sold
SSPX0043
Front idler pulley with motor mount $40.00 sold
SSPX0044
Both exhaust manifolds with EGR $30.00.
SSPX0046
SSPX0045
Complete heads are $75.00 each. Includes cams and shims. These heads are in excellent condition and only need to be cleaned up and new seals installed to function.
SSPX0051
SSPX00521
SSPX0049
SSPX0050
Complete and in excellent condition 3.2L wiring harness. $50.00. You won't find one in better shape.
SSPX0058
Compete and excellent condition fuel rail and purple injectors. $40.00
SSPX0059
Shipping is extra from Zip 28804. Thanks.
jimtash
nc
I don't know for sure. I bought it off a guy who was going to use it for a project and he was told it had roughly 40K miles on it. I'm guessing around 80K-100K miles because the timing belt and water pump had been changed on it.
The cam chain tensioners work flawlessly and the lifter buckets still spin freely. The only problem I encountered during the teardown and rebuild was a lot of varnish inside the engine and guessing that's from the owner using drive through oil changes and sitting for years. I would post pics of the rod bearings from it but I tossed them. They had limited wear and the main bearings were in better shape. I wouldn't hesitate reusing them but had a spare brand new standard size set laying around and those went in instead.
To give you something to go by though, the runner couplers on the intake look and feel new. They're not dry rotted nor faded and neither are any of the components on the intake itself. Look at the wiring harness as well. The tape surrounding it isn't brittle and the condition of the wiring itself is excellent. This motor has not seen much use and was well stored for sure. It's why I bought it.
SSPX0047
Black Bart
maine
great seller, parts came qick and as described. thanks again and bump for you
ribeye2065
