60+ Gen 2 ATX Auto 3.2 Opal Frost - body, interior, engine parts
Form1le
Lansdale, PA
Open to offers on this stuff.
Parts off 1994 Taurus SHO ATX Auto 3.2L. Car & engine had 230K+ miles so please take that into consideration as I’m selling all parts AS IS with no returns. New parts listed below have virtually no miles as I only drove the car a few hundred miles. Car was scrapped, so this is all I have left. Exterior Opal Frost, Interior gray leather. I’ll try to include mounting hardware where I can. Prices do not include shipping. Big stuff will be hard for me to ship. I’ll start a separate section below for what sells. I live in Montgomeryville / Lansdale area, close to Doylestown, suburbs outside Philadelphia.
Here's what's left:
Rear bumper cover with absorbers and reinforcement - $100
Header panels - both aftermarket, $20 each
1st - fit well but has lower mount hole missing for driver side marker
2nd - did not fit well and shop ended up cracking it in a few spots
Passenger side marker - original, $20
Driver taillight, original - $20
Passenger taillight, original - small crack & light scratches, $20
Rear License Plate Molding / Valance - $60
Rear spoiler with 3rd brake light - $100
Left rocker molding & ¼ panel lower claddings- $60
Right rocker molding & ¼ panel lower claddings - $60
Stainless steel rocker molding bracket - you may need to cut other holes to mount it, - $60
All 4 Door trim panels & Front and rear leather seat cushion set - $100 for all of it
No front seat frames/tracks. Front seats worn, trim broken, stitching on top of rear seatback is coming apart, bottom in good shape
Driver fender & liner with cladding & 24V emblem - $60
Passenger fender & liner with cladding and 24V emblem - $60
New set of NGK platinum plugs, Airtex wire set & ignition coil pack with cover - $60
Reman Alternator – no miles, $80
Alternator (core) - $20
New Starter - just installed, $40
Battery tray - treated rust and painted with black Rust Reformer, $20
Mass air flow sensor - $20
Throttle Body - $20
PS pulley - $20
Cam pulleys - $40
New Timing belt idler pulley - $60
Plunger type timing belt tensioner -leaking, $40
Pulley type timing belt tensioner - $40
Timing belt tool kit - $30
Serpentine belt tensioners x2, no pulleys - one i suspect was original to car with 230K, the other I installed but felt notchy (spring rusty) - $20 each
Harmonic Balancer - $40
Rear audio electronics - I have no way to test if they're good
Rear amp set - $40
Rear subwoofer - $60
Dash cover / cluster surround panel - $60
Glove Box - $20
Front door switches (driver new, pass used) - $20
Emergency brake pedal assembly - $20
Wiper switch - $20
Automatic climate control module - $100
Valve cover gasket set, installed briefly but was brand new - $40
New aftermarket IAC valve , I'll throw in old Ford unit. Replaced as I had IAC code - $40
Steering column metal cover - $20
Sold
Air box
Fog lights
Console
Serpentine Upper Idler pulley x2
Serpentine Lower Idler pulley
Catback exhaust
DavidT
TN
Do you have a center console latch. I need the piece that's inside the upper lid. Thanks
Dindindena
Parts off 1994 Taurus SHO ATX Auto 3.2L. Car & engine had 230K+ miles so please take that into consideration as I’m selling all parts AS IS with no returns. New parts listed below have virtually no miles as I only drove the car a few hundred miles. Car was scrapped, so this is what's left. Exterior Opal Frost, Interior gray leather. I’ll try to include mounting hardware where I can. Prices do not include shipping. Big stuff will be hard for me to ship. I’ll start a separate section below for what sells. I live in Montgomeryville / Lansdale area, close to Doylestown, suburbs outside Philadelphia.
Front Bumper with absorbers, reinforcement & SHO plate - has some road rash and puncture that can be covered by plate - $100
Door trim panels - $20 each
Front and rear leather seat cushion set - $60
Catback exhaust that I pieced together with AM parts, not stainless - $400
Includes flex pipe, intermediate pipe, rear Y pipe, Dynomax Super Turbo Mufflers w/ original tips - custom mounted passenger side so you may need to customize or get bracket welded for correct mount
Original rear Y pipe - $60
Set of 4 16” Slicer wheels, tires (7/32 fronts, 4/32 rears) caps & factory wheel locks - $200
Reman Alternator – no miles, $100
New Starter - just installed, $60
Throttle Body - $20
PS pulley - $20
Cam pulleys - $40
Serpentine Upper Idler pulley with new bearing installed, also fits tensioner - $60
Serpentine Lower Idler pulley - $40
Serpentine belt tensioner w/ pulley - $40
Serpentine belt tensioner, no pulley (spring rusty) - installed and it was notchy so took back off - $20
Pioneer Bluetooth media player with 6.5’s, 6 x 9's and mounts - $80
Rear amp set - $40
Glove Box - $20
Wiper switch - $20
Sold
Air box
Fog lights
Console
I am interested in the tensioner puppies the 60 dollar one with new bearings and the 40 dollar one how soon can you ship these?
Dindindena
I am interested in the following:
Form1le
Lansdale, PA
I can't edit original post even though it's less than a year old. Anyway, this is last call on big stuff like bumper & header panels before trash probably. Small stuff will go to ebay as I get time. Please send me all offers as I'm ready to get rid of this stuff, thanks
wjayg
Idasho
Boise
What manufacturer on starter?
How much freight to 83714
I might buy a lot more if you made me a quantity discount
wjayg
Idasho
Boise
The AC heater module showed up the one in the dash it looks perfect thank you you wrapped it unbelievable with bubble wrap extra wrapping everything what a great deal thank you it looks brand new
Form1le
Lansdale, PA
No, many of the parts from the original post are gone but I don’t have the ability to edit it.
If anyone is interested in seeing the list of remaining parts, pm me. I don’t want to be charged anything else on this forum for putting the updated list here.
Form1le
Lansdale, PA
Shut down my account, delete the thread or whatever. All I’ve tried to do is help people get parts that they need at great lengths in some cases. I still don’t know why I don’t see an edit functionality but I finally get a response from you. I’m disappointed that I keep telling people I don’t have what they need.
Irish Pride
Irish Inside
MusicCityUSA
People, this is a paid classified ad. If you do not have anything positive to say about his ad or what he is selling then keep your thoughts to yourself.
OP, PM me the updated list and I will update the thread again. You are not required to make another donation. I'm not sure why you don't have an edit feature yet.
lingyuair
