1994 Taurus SHO White 44k miles
tompumped
VT
The chances of getting so many bad used sensors is impossible. Its either intermittent wiring issues or more than likely coolant leaking on it. The coolant leak could be a small drip that evaporates and isnt visible.
Ive never had a problem with the pump o rings failing only weeping out of the hole. Then again I change my pumps and crank sensors at 70 to 100k. Ive also never had issues with crank sensors failing and even sold a used one recently that works fine. Ive had a sho on the road since 02 and they were my daily during most of that time until recently.
Tim Devine
St. Augustine
Yes, the original one in the car that I bought new failed from coolant leaking into it, this is the first used one I purchased that has this issue. Same exact symptoms as when my original sensor was cooked from coolant.
Will
central ohio
Not sure if this is still around, but sent you a message. I'm off all week and have an empty trailer :)
Old Stang
Woodstock, GA
Well, the SHO arrived in my driveway safe and sound on Friday (9/04), now the fun begins!
I can't say enough good things about the seller; Tim was very honest and transparent about the car and extremely patient and helpful with the coordination of the shipping from FL to GA. Thanks again Tim!
I'd also like to thank the SHO Forum as I would not have found this SHO had it not been for them ... especially keeping my login info since 2008... LOL!
