I'm 99% sure the answer is yes, but even if not, why wouldn't you? All you have to do is move the stud to a hole that's already tapped and add a dowel that's already drilled out. Not to mention the ATX tensioner fails more, being hydraulic.
ok so i got the 3.0 tensioner off the old motor and got the pin relocated to the 3.2 block but know how do i get the bolt out of the 3.0 block and into the 3.2 block?
Take two nuts that will thread on to the stud put one on there and tighten the second one on after it then loosen the original one you put on if that makes any sense. The stud should thread out. Mine did when I did my 3.2 swap.
