Speedie13
That's Decent!
Like i said, the 3.2 in my 93 is making a strange clicking noise that I believe JUST recently started, two days ago or so. It sounds like its coming from all over my engine....mostly on the top I think. I will go out and try to get a better listen.
I took a little video of it earlier that I have a link to. Its good quality but very very dark for some reason unfortunately. I will let you know that I start by the intake/TB and go back and forth over the motor. I can hear the clicking fairly well over the pass. side of the motor and coming from the air filter (which if you cant tell from the vid. is when you can hear a LOT of air being sucked in as well as the clicking sound). It also is somewhat loud over by the pullies.
Ive done some researching about the noise and have read that the most common noises like this are either rod bearings, valves, or just normal (slightly louder) engine noise.
Anyway, sorry again for the dark vid but you can sort of make out where im going with the camera and you can see me go over the front valve cover a few times. If it totally sucks I can go out and try again.
Let me know what you think.
Strange Noise?
Strange Noise?
