3.2 MTX - No start.
SHOspazz92
Banned
Triad Area, North Carolina.
Today I drove Ashley's SHO home from the store. As soon as I got home and shut down the car, I decided to start it again to re-position the car.....and nothing. The car will not start. I have Fuel, Plenty of it. The Starter can be heard BARELY Clicking (At least I think it's the starter I hear clicking).
Anyways, Since my driveway is down hill, I decided to pop start it just to see if it will run. Got it rolling, Released the Clutch and it starts right up.
Now, Should I got ahead and assume that the starter is shot? I've checked all Fuses, Wiggled around the Wires on the starter itself, Tapped the starter with a Hammer, Nothing. The car has never had issues with the Starter and generally starts up very quickly (For a car that has Oil in 3 of the plug wells, don't worry, That's getting taken care of soon as well :nut: ).
Keep in mind, The car will run if pop started.
Any other Idea's? I HAVE to get this fixed very fast as I deploy on Saturday for 6 months. She'll have my truck to drive, But I don't want to leave her pride and Joy sitting in the driveway not working.
-Sam
Racer X
SHO Pilot, Retired
Connecticut
Sam, jump the starter solenoid terminal to the positive terminal of the starter with a long screw driver. If the engine cranks, look at the ignition switch. If no engine crank, starter is shot.
Keep your head down over there, Sam.
SHOspazz92
Banned
I hate to say it, But you lost me here.
The positive Terminal is going to be where the Battery Cable connects to the Starter? And the Solenoid Terminal is where...? It's hard for me to Imagine this without being under the car.
-Sam
whiteman_01
Well-Known Member
Hastings, MN
I would bet its the solenoid on the starter. I have had the positive post break on them more than once. Also make sure the switch wire is still in tact before you pull it all apart.
milestoldyouso2
new york/maine
there is a red cover on the end of the solenoid (unless it has fallen off) pull this off and there will be two large studs with nuts, one conected to the battery cable and one conected to the starter motor istself, use a screwdriver and touch the two terminals at the same time, (expect some sparks) if it cranks than its a bad solonoid or somthing is not triggering the solenoid, if not its a bad starter motor, if it cranks then pull the smaller conecter on the solenoid located on the side of the two posts and apply power to it with the screwdriver across the battery cable terminal, if it cranks then there is nothing wrong with the starter/solenoid and your problem is most likely the key switch or something else down the line like the clutch petal interlock or somthing, good luck!
SHOtimer
#2910
Santa Clarita, Ca
Try knocking on the starter with a hammer or the spare tire lug wrench. It should work after you knock it. If so, the starter is binding and that is your problem.....
I can swap the starter in my ATX in 15 minutes....damn Autozone starters. I just replaced my 8th one yesterday.
Doug
93rev2sev
Hockeytown
All I have to say is...
My brother was lucky he was on a creeper...and that he backed into the garage.
shobote
Naperville, IL
Had similar problem with my Mitsubishi; The copper contacts in the solenoid can get oxidized over time and then lose conductivity. I replaced the contacts in my Mitsu for a few bucks, but not sure if they can be bought for the SHO. You could also try filing the surface oxidation off
hawkeye18
Sorta cares
Norfolk, VA
Starter is good. The Ground on the starter had come off. Free Fix FTW.
-Sam
Yay! I should've thought of that, too; the exact same thing happened to my 94 a few years ago. Just goes to show just how many problems a bad ground can mask itself as...
