3.2 heads on a 3.0
Seafox
Central NY
Does anyone know if heads from a 3.2 will work on a 3.0? I know there are differences in the engines other than the displacement so I'm not sure.
Thanks!
Mr Anonymous
Tire Wall
Seafox:
Thanks!
Yup, you just have to grind off the ATX alternator mounting boss from the 3.2L front head. The rear head is a straight-swap. The 3.2L cams are 'de-tuned' from the 3.0L cams, so you'd probably want to swap the cams too.
Seafox
Central NY
Thanks, I was wondering because I might be able to get a set of low miles 3.2 heads cheap and my SHO is looking like it needs new valve seals, this would be cheaper than trying to rebuild the current heads.
SHOMurph
Ford B@stard
Arlington, TX
You have to cut and modify the front head 3.2 head to fit. The valves are the same size so no gain there.
I would search for some 3.0 heads.
thatSHOguy101
