3.2 cams in a 3.0?
SHOman24v
Fresno
i have been thinking of putting 3.2 cams in my 3.0, is it possible? what kind of difference could i expect? is this something worth doing or should i just buy stage 1 or 2 cams?
Mike Kopstain
Arlington Heights, IL
You're taking a step in the wrong direction. what most people do is stick 3.0 cams in 3.2's as they have a slightly (8%) higher lift on them. Not worth your time. Go to SHO Shop.
1slickRED89
Guest
Toledo Ohio
might be worth a try! when talking about the 3.2L engine, alot of people say that the 3.2 cams help in the low end department while the 3.0 cams are more apt to the upper rpm ranges. since the 3.0 is that much smaller in displacment, the lower lift intake cams might not limit the top end like it is said to on a 3.2. give it a shot if you can. i'd be interested in the results. Corey
