nkb93
SLO 4 SHO
3.0 vs. 3.2 PCM
I'm going to put the 3.0L PCM in my ATX to MTX swap car, and I want to retain the ATX fuel pump and fans. I had a few questions to make sure this is going to work:
I think the 3.0L PCM is programmed to run the fuel pump at two speeds (hi/low), and that the 3.2L PCM runs the fuel pump 'hi' all the time. Is this correct? Are the fuel pumps physically the same?
Along the same lines, the 3.2L PCM can run the cooling fans at two speeds, while the 3.0L PCM only uses one speed (high). Hypothetically, would there be any problem running the ATX fans single speed (high) only?
TIA-
Nate
TIA-
Nate
