3.0 and 32. valve covers the same??
gregr
Orange County, NY - USA
Anyone know if the 3.2 and 3.0 valve covers are interchangable?
Thanks.
Greg Raciti
SHO Forum Webmaster
93 Emerald Green MTX
Performance Plus high flow stainless Y-pipe
Scott 2.5" Mandrel Bent Stainless
Exhaust with Edelbrock mufflers
SHOShop Cold Air Induction
SHOShop Underdrive Pullies (to be installed)
Romar Enterprises Subframe Connectors
SHO NUT Performance Aluminum Subframe Bushings
24mm front sway bar
26mm rear sway bar
Energy Suspension poly bushings
Rob94
Northbridge MA
Greg, On Josh's SHOnut Performance, there is only one part number listed for individual vavle cover gaskets, LH and RH.....no reference to 3.0 or 3.2. With that being said, I would assume that they are one in the same. Hope this helps.
Rob
White 94MTX
Stock
I replied last night with the word, "Identical," but for some reason it wasn't posted.
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
