245 size tires in 1st gen..?
REDSTAR
Phoenix, Arizona
it's just about time for me to replace my tires.. would it be at all possible to stick 245 size tires with a aspect ratio of no less than 45 on a sagging stock suspension 1 gen taurus.. i am willing to shave some of the lip off the rear fenders in order to get them on.. any info is appreciated..
jedhead
westminster,ca
I have seen a gen I with 245/45-17's on TSW EVO's. The rear fender required the lips rolled.
Bob
speedy91
West Des Moines, IA
I run 235/45R17 on my street wheels (17x7.5 40mm) and 225/50R16 on my track wheels (16x7.5 35mm).
Eric
Edit for wheels info.
<small>[ April 14, 2003, 02:08 PM: Message edited by: speedy91 ]</small>
Not on 6" wide basketweaves. Got wheels? Even then, a 245mm section width would require a significant amount of fender trimming.
REDSTAR
Phoenix, Arizona
i have 17x7 wheels with an offset of 38mm ??.. im not positive of the offset.. but they are asa em9's.. if anybody knows the offset for those wheels..
steevil
Edmonton, Alberta Canada
225-45/17" on a 7.5" rim with 40mm backspacing.
Lowered 3"
There is less than 1 inch clearnace on the rear fenders and occasioanally the fronts will rub.
You may get away with it if you had 38 mm backspacing but it sure would be close.
Dave Kegel
Chicago suburbs
Lowered 3"
38mm offset will put the tire closer to the fender than 40mm, not farther away.
Dave Kegel
tinkerkathleen
