Blackdr16
93 SHO
Hi all!
Quick question. My 2011 SHO is constantly cycling the AC clutch while idling or driving. Have 41K on car. My first thought was the freon was low so I checked pressure. Low side Im getting around 28 PSI. This has dropped to around 25 but no lower as the compressor kicks off - pressure climbs then clutch kicks back in and repeats the cycle again. I added 1 can of R134 while watching the pressure climb. After one can the low side stayed around 35 while dropping down to 32 at the lowest before kicking off. The fans now are coming on and staying on high while the clutch is engaged. (Normal operation, but shouldn't be on the highest speed) The clutch continues to cycle in and out about every 40 to 60 sec. AC is very cold inside the cab, so its more an annoyance while driving feeling the clutch kick in and out. Anyone have some suggestions or know what pressures the high and low should be at under normal operation? Ambient temp is about 80F currently. Thanks!!!
