2 stage nitrous setup
bubba
ATX Connoisseur
Fort Wayne, Indiana
I was wondering if you could do this setup. One would before getting off the line. At wot. I would want it for show and go. I seached this and found nothing on it. I would want a 50 shot and maybe a 75 for wot. Any input would be helpful. Thanks Dan. I read this on other forum along time ago.
AREA 91
PA SHO SHOP
Area 91
You can accomplish what you want with a dry system. Easier to plum and use.
baySHO_510
**** It broke!!
Manteca & Oakland Ca.
I went with a 155lph fuel pump from Summit (meant for a Mustang 5.0) & some copper plugs from Napa Auto parts. I was running a 75shot & now I have a 100shot nozzle in it. I ran a 14.09 @ 98mph.
SLoW_SHO_316
Runcarsnotwords
Connecticut
You really should never spray when you arent WOT.
AREA 91
PA SHO SHOP
Area 91
You can't spray unless you are at WOT on a dry system.
Start out with small jets, and then work your way up.
Autolite 3923 plugs (1 step colder than stock)
A new 155 LPH fuel pump
a second job to pay for bottle refills.:thumb:
bubba
ATX Connoisseur
Fort Wayne, Indiana
I just wanted a second stage ready if needed. Just at wot on both of them, just different shot at different times. Thanks again.
SLoW_SHO_316
Runcarsnotwords
Connecticut
You can't spray unless you are at WOT on a dry system.Start out with small jets, and then work your way up.
Yes you can. And you shouldn't. The OP said he wants a 2 stage, 1 for getting out of the hole, and one for when he hits WOT. He'd hit SHO boom outta the hole if he tried spraying before he was WOT.
AREA 91
PA SHO SHOP
Area 91
They make a plug in module that will control 2 seperate systems.
I have a controller on my system. I can set what RPM the system arms and dis-arms. I can even block out gears.
bubba
ATX Connoisseur
Fort Wayne, Indiana
That's what I was looking for. I think they call it a window switch. Where can I find that controller at? And will it work with a Zex kits?
That's what the wife is for hahahahha
bubba
ATX Connoisseur
Fort Wayne, Indiana
Yeah I thought I'd go Sho Boom out of the hole. That's not good.
What if I sprayed out 2nd gear?(I have a auto). And then in top gear? I think that would do?
AREA 91
PA SHO SHOP
Area 91
This is what I have.
Traction Control Window Switch
PART #82085
None of these are in your basket
$192.61 ea.
QUANTITY:
Let's you select what rpm the nitrous activates and deactivates
Allows you to select what gear the nitrous starts spraying in
Fully programmable and adjustable up to 20,000 rpm
Easy installation with complete instructions
