Taurii, like most production sedans, come from the factory with lots of oversteer built in. IMHO, if you let your rear tires get so bad that you're in danger of oversteer on the street you're way past the point where you just need another new pair of tires.
And when you get them, put the NEW ones on the FRONT so that you can STEER and BRAKE. These, steering and braking, are things that you do all the time, and IMHO if you're going to get into trouble where you're gonna need to put the tires near their limit it'll be much more likely that it'll be needed on the front than on the back.
On a FWD car the fronts are going to wear much faster than the rears if the alignment is healthy. I check tread depth front and back periodically (especially just before and after track events), and always rotate the tires with the most tread to the front. Since I do a lot of track time I wind up moving the rears to the front a few times a year. This way I wind up with four tires that reach the end of their useful tread life at the same time. If you put the worst tires on the front you're killing your tire rotation opportunities and you'll eventually wind up with bald tires on the front and plenty of tread on the rear.
And I don't agree that oversteer is harder to correct on a FWD, I find it much easier. On a RWD car if you're hitting oversteer and correct with throttle, you have to be very delicate since the rears are already in the region of their traction limit and adding throttle only exacerbates the problem. On a FWD car, if the rear is starting to drift there's already more grip at the front than at the rear and throttle correction works wonderfully. Hammer it and it straightens out. In my experience you can recover much deeper in a drift with FWD than with RWD. If you're also turning into the drift that's all the better on a FWD, since now you're taking slip angle out of the front so that you can use more of the traction capability for thrust to put weight on the rear.
This is why Danny Sullivan says, "The way to race a front wheel drive car is flat-out."
IMHO, YMMV, etc., etc.
