1999 Ford F150 4.2L V6
MauriceZ
Starter went bad and did not disconnect battery before replacing the starter which caused a relay to burn. Connected new starter, replaced all relays in engine bay and in cabin. Truck starts and runs for 5 minutes, then RPMS start to run low and then dies. When put into drive or reverse, truck tries to stall unless you try to stomp on the gas, and will drive but with a complete loss of power only running on approximately 20%. Idles decently in Neutral and Park but only for about 5 minutes or so before trying to stall out. Tested fuel line pressure and it is at 35 where it should be. Service engine light does not turn on and no codes have been thrown. Please help?!?!?
did you actually put a code reader on there, or just assume that because the cel is not on there are no codes?
most likely you fried more electrical stuff (like the pcm, etc.) but until we know the codes we are just guessing...
