1994 sho new guy going turbo.
Michelle
Wisconsin
Yes, I am on BCM. I had Adam from Pops Racing out in the northeast remote tune it for me. Only running 7 pounds of boost.
sho85
Wisconsin
Thats who i was planning on having tune mine too.you ran your maf blow through right?
sho85
Wisconsin
Drilled out broken bolts on the manifolds header wrapped the y pipe and manifolds. But i forgot to weld on the wastegate ****** ohwell i wrapped the y pipe in sections so only have to undo like 2feet worth. Waiting on the oil pan bung being welded then i can put the pan on and the ypipe and manifolds then build the down pipe and hook it up to the stock exhaust.
CAM00644 zpsc355a18e
Toolman
Boost it!
Grand Lake, Oklahoma, USA
This setup is similar to yours, running pipe behind subframe then up in front of trans.
sho85
Wisconsin
Pulled my abs off.didnt want it or the extra weight. Yea i sort of copyed your ypipe ha.
Dirk37
Mr. Resourceful
Washington
I was working on making my y-pipe tonight based on your guys pictures, and I ran into an issue, how are you guys tightening the bolts holding the y-pipe to the front exhaust manifold? I played with it a bit and the pipe is always blocking access to the bolts. It looks like the only way is to stick a wrench above the sub frame from the front of the car.
Also where are you guys getting oil for the turbo from?
Toolman
Boost it!
Probably going to have to use and end wrench.
For oiling my turbo, I have an oil filter relocation sandwich with different ports on it. One feeds my turbo, one feeds one of my oil pressure gauges, and another my oil temp.
Also, other setups have used the stock oil pressure location ( near rear of engine, close to trans, you should be able to see it if you look past the hard coolant lines for the heater core) and teed off a turbo feed line.
sho85
Wisconsin
I was just gonna tee off the factory oil pressure sensor. And yeah i pretty sure if i use a swivel i can tighten the front ypipe to.manifold bolts but using a wrench wouldnt be too bad either.
tinkerkathleen
