Lurch
Ok, here's the deal: I can hardly get my SHO in gear. I'm pretty sure the clutch is not disengaging all the way, but I would like to hear some opinions from people in the know, as I have had the car less than 24 hrs. I can mash the clutch to the floor, and must use waaaayyy too much force to get the car in any forward gear. I'm talking bracing on the seat and pushing to the point that the shift handle flexes. When it does go in gear, it does with a thud, like it finally gives and goes in gear. There is no grinding like I would expect with a clutch that is not disengaging all the way, and I can hear what I think to be a throwout bearing problem. Also, reverse goes in fairly easily, but there is a grinding as it goes in. Yes, I know to wait 3 seconds after taking the car out of gear to go to reverse, but the grinding happens anyway. Of course, any shifting at all is only possible because the clutch is ON THE FLOOR HARD. I have tried the "pull up with your toe and then press down" to auto-adjust the clutch to no avail. What does this sound like to you SHO gurus? Do I need a clutch, tranny, TOB, bullet in the head for getting a car with a known clutch problem (that was much less pronounced yesterday)? Should I try to drive it to a shop/garage/dealer, popping into gear all the way, or have it towed to its destination?
PS I am 17, and have no prior experience tearing things (read "transaxles") apart. I don't relish doing this work myself, so unless it is a fairly simple solution I believe I'll take it to a professional (read "con-artist"). Though I am car literate.
