1989 SHO Fuel pump/sender issue
Rich G
NJ
My fuel gauge is not working properly and it was determined to be the sending unit in the tank. It should be part number E9DZ-9H307-D.
Now discontinued from Ford. My mechanic ordered 2 non Ford parts from his supplier who said they will work, but neither one did.
They did not have the separate wire terminal like the original. Only the 4 pin plug. I have looked online and found the original part but in the description it says its for a digital unit. And some that looked correct said it would not fit my car. My fuel gauge has a needle pointer.
What are they referring to by digital unit?
Will the E9DZ-9H307-D work with my dash? If not which other brands might work?
Thanks, Richard
I remember Topaz or Tempos had digital dashes maybe even taurus? I think sable for sure but I don't remember the exact years. Maybe some of these parts cross over models?
If your listed part number is correct for your car then https://www.ebay.com/itm/162021290394
Tasca lists this F4DZ9H307AA
as a valid part number also. Have to double check that. If correct I think there are some of those on ebay as well.
Irish Pride
Irish Inside
MusicCityUSA
The correct part number for the SHO is E9DZ-9H307-B. That is the only option for the 89 SHO.
E9DZ-9H307-D is specific to the regular Taurus with the optional 18.6 gallon tank and digital dash.
Do you have any pics of your pump? I'm confused by what you mean with the seperate wire terminal. Every SHO sender that I've seen has had only the 4 pin connector.
-Chad
Rich G
NJ
Unfortunately I didnt see MY fuel unit when it was out of the car. But my mechanic says it has this extra terminal
in addition to the 4 pin plug like this one in the photos I got from an Ebay ad. It comes from the sending unit. I looked for the E9DZ-9h307-B and didnt find anything. My SHO was built in November of 88. if that helps at all.
-Chad
Same here re: 4 pin connector. Chad, are the other SHO model pump sending units compatible? I am seeing this bosch unit with your oem part number in the interchange list here..
https://www.lmshayrato.com/index.php?main_page=product_info&products_id=168454
Rich G
NJ
In the photo above you can see a threaded post coming through the lid separate from the 4 pin plug. This is what my mechanic says I need. A single wire plugs onto this post. Which is connected to the float assy. I did not see the unit while it was out of the car, so I dont have photos. I wish I did. I will talk with him and try to get more info.
Thanks for the help so far,
Rich
yeah I wonder if the angle on that bosch unit isn't showing it or it doesn't have it. Have you thought about getting a used unit?
BaySHO Performance
SF South Bay
-Chad
Chad, my records have that PN for the pump itself, not the sender.
I had an '89 in back in 2014 with the same problem: the fuel gauge wasn't working properly. I first checked that the resistance at the sender was correct. From the '89 shop manual:
IMG 20220620 104704033 769x800
That was OK, so the sender was working fine. Turned out to be the slosh module instead of the sender. This is a baby board plugged into the back of the instrument cluster. The only way to get one was to buy a whole '89 cluster from a wrecker's yard. Replacing the slosh module fixed the problem. Any slosh module from a later year won't work. I don't have the PN to search on.
To find an '89 in a yard: https://row52.com
Don't know whether a mechanical instrument cluster from a regular Taurus will work. To select just the SHOs from the list of cars that came up, switch to a VIN search and enter P54 into boxes 5-7. The only '89 SHO in the whole country:
Rich G
NJ
Thanks for that info, Nick. I was not aware of that part. Something I will mention to my mechanic. I believe he said there was a burn mark in the middle of the wire where the float connection makes contact. It could be a while till I can get the SHO back to him but I will post when it gets fixed.
Update, It took a while till i could get my issue resolved. But I had the new fuel pump and sending unit installed.
There was some confusion on which pump that should be in my car. Here are photos of the original pump that was removed.
Also photos of the dash. I know some of you said you have only changed pump assemblys with the 4 pin plug.
Im still not sure if I have the digital dash or not but I do have the EAC heating system if that makes any difference.
The replacement pump and sender we used is from Carter. # P74591S.
Its good to have a working gauge again.
IMG 0941IMG 0942IMG 0943IMG 0944IMG 0945IMG 0946IMG 0947
Rich
thegreatbriguy
Carlisle
I'm a little late to this thread but I have a few cents to ad. My 89 has the wire for that top threaded post. However, i have installed lots of pumps since then that don't have it. I left the wire hanging....
Also discussing at the convention we agreed that any 155lph pump will in fact work even though the 89 is a two stage pump with 180lph. Later sho's did not have that option and they run properly on the 155 lph. I installed a pump from a 3.8 and 18.6 gallon tank and its working well.
Also, if you plug is bad the plug from a ford ranger fits properly. My plug was a little burned/melted too.
