Tim Nicholson
Hi, I have a problem with the charging system on my 89SHO. The battery appears to be over charging (boiling) causing battery acid to leak down on the battery bracket, etc. I replaced the alternator but it still looks like I am getting some leakage. Question is the voltage regulator, is it in the alternator or is it external? The Ford service manual isn't real clear for the SHO. Voltage at the battery while engine is running is <14.5V. If the regulator is external where is it? Rock Auto shows a listing for a regulator for the 89? Thanks in advance
