redsho
Need 4 SPEED
Did some searching - seems like consensus is stating to go w/ 38mm offset for this size wheel.... But who have sucessful run this size wheel w/ 235/40R18 tires w/o rubbing (fender or struts) issues on a GEN II
SHOWYA said:i have 18x8 with a 40mm offset. Since the car is drop it will slightly rub in the rear when you hit some bumps hard but this is because i went with a tire that is 245/40 18. If you have not lowered your car, you should be fine with 18x7.5 and 235/40R18 tires.![]()
SHOWYA said:I had the Eibachs installed when i got my Koni inserts installed, and did not notice a slight drop on the vehicle. Thats why i switched to the intrax springs even with those after a break in period only lowered the car about 1/2 inch. So i cut one of the coils on the springs .... and now looks much better take a look of my sig pic below!
So you should have no problems with that combination since the eibachs are not really going to lower your car much.
I still have the eibach springs ... anybody interested? About 1000 miles onthem ... still new!
redsho said:Showya...
Nice car! BTW, how heavy is your car now? It seems like you're running 40 series tires. I've seen some people run this low-profile tires, but most of them don't have a large audio system. My system weighs 300+ lbs, so I'm not too sure if the 40 series tires would be safe. How wide of a tire do you use - I thought you didn't need to trim fenders if you're using 235 or less
