170 Thermostat
17BlkSHO
NOVA
Just installed the Reische 170 thermostat, drained the coolant, and replaced it with the yellow coolant.
Since install, my temps be fluctuating between 185-168. Even cruising I’m at around 175. I had a shop drain and fill, but did the burping procedure myself just in case.
Is this normal with this thermostat?
I did notice when cruising downhill the temps 9/10 times drop to 170.
Thanks
kryptto
South East, Florida
Thanks
I have it installed down here in FL. those ranges are normal. however living in Nova Scotia why? your ambient temps are low.
just remember too without a tune to change when fans kick in you will always float up in temps.
do u have any mods where I might wish to try keep things cooler.
17BlkSHO
NOVA
I’m located in northern va (called nova here locally).
17BlkSHO
NOVA
I did talk with GH, and I told them I was finally getting around to installing the thermo and informed me no change in tune is needed (I already have their tune with colder plugs installed).
shoblock
Cleveland and Naples
I have the same thermostat with the GH auto octane tune in my '15. I put in a new 170 stat last year and it took awhile for all of the air to work it's way out of the cooling system. The temp gage jumped around during this purging. The gage is now repeatable each time I run the car. A Ford mechanic friend advised that tuners usually tune so that the gage shows the exact reading at all times, so it makes sense that the reading will fluctuate until all air is purged.
SHOBLOCK
kryptto
South East, Florida
look it opens at 170, now if the ambient temps and normal driving your car will creep into 180 plus or minus a few. mine can fluctuate between 180 and 190ish. however with the humidity and 85 average temps it's to be expected.
I noticed a good air purge process there will be small fluctuations for sure still the air is gone.
@shoblock I get that plaid?
shoblock
I put way too much time in replacing the thermostat. When I first tuned my car at 17,000 miles, using the cursed Livernois tune that tried to take out my turbos and transmission, I used the Livernois 160 thermostat. That piece of junk is really the $10 Auto Zone thermostat that Livernois modifies to open at 160. This stat froze shut early last year, but I was having issues prior to that. When I wisely threw out the Livernois parts, and after installing all of the Gearhead parts, I was too lazy to take out the 160 stat because it was working okay at the time. It froze shut in January of last year while in a sub zero Ohio day, and I had to nurse it home with windows open and heater on full blast. I then purchased a Reische 170 and proceeded to drain the system and replace the stat. I found out too late that I was shipped the wrong stat by the vendor (it was for an F150) and had to run to the parts store to pick up a stock 180 to use until the 170 Reische could be replaced. Again, COLD January in OHio. :(
I use the 'spill-free' funnel to get the air out after I first button-up a cooling system, but there is always still a little bit of air stuck in the crevices. Knowing the castings as well as I do, I know where the air can hide. This air puges with time.
I then used my Autel scanner full-time while driving, to monitor exact temperture +/- 1 degree. The temp with the stock stat jumped around like a ham on a hook. Fluctuations in temperature ranged at least 30 degrees. In Spring, I got the correct Reische and went through the install all over again. At least I won't have to change anti-freeze for awhile.... The Reische took about 3-400 miles to normalize the readings, and I constantly compared the factory gage to the Autel. They were both very accurate and reliable.
I'm very happy with the GH tune and the Reische stat in my 13.0 work car that gets 22+mpg,and it's worth the extra effort to do the WHOLE GH package at once.
The Plaid will come in early fall when I return to FL for the winter.
kryptto
South East, Florida
great story and share, others can learn from it. I must of not been paying attention as closely, my temps stay low, and have watched when the tstat opens now. on the dot 170. the weather is warm come on down!
17BlkSHO
NOVA
SHOBLOCK
Thanks. Yea, I spoke with GH and gave them my readings. They said everything looks perfect.
