17 x 8 Rims for the SHO
kmetros
Drug Pusher
South Bend, IN
Any of you running 17 x 8 rims on your SHO's? My rear wheel wells are shaved and I'm looking for this size rim to put on the car. I guess I'd settle for 17 x 7.5, but I'd rather go to 8's. I know about the OZ Superlegga's (or however you spell it), but was wondering if there were any others anyone knew of?
SHOOFF13
SHOOFF
Massachusetts
I'm running 17 by 9 Cobra chrome rims on my 95 SHO. I have a minor problem with hitting the rear wheel wells when I hit some hard bumps. I plan to shave the rear wheel wells soon so it won't be a problem anymore. I think 17 by 8's would be fine on your car in my opinion.
Shoaz
Studly dood
Scottsdale, AZ
You can get ROH Snypers in 17x8 for the SHO. PanamaPat and a few others have been using those for a while. I'm using the same wheel but in 16x8.
BlownByU
Guest
New York
I'm running 17x8s on my car with a 235/45/17 tire on there and have had no problems. The rear rims are rediclously close to the stut housings but do not hit. I actually had to use stick on wheel weights though or the wheel weight would have hit. I can try and find the offset if you want.
SinisterSHO
Rust free
630, IL
Do you know if they ever made those in an 18x8? Also, where are they available? I haven't seen them for sale anywhere online, but Discount Tire says they can get just about anything.
kmetros
Drug Pusher
South Bend, IN
Which rims are they? Make and model?
Shoaz
Studly dood
Scottsdale, AZ
When I got mine I had been working directly with the importer. The Discount Tire that I usually work with for tires asked if they could take a shot at it and got the same set (there was only one set left in the country at the time) for less $$ than what the importer was going to charge me.
So, yeah, give DT a shot.
GeneSHO
Canada
Will be using these Borbet 17 X 8" (40mm offset) for track use with Kumho V700 rubber ... wheel combo currently for the street are MMII 17 X 7" w/Bridgestone S-03's.
I believe Dave Kegal had the same wheels on his blue Gen1 also:
IT-Purrrs
Royal Oak, Michigan
Kurt,
Im running Millie Miglea's that are 17 x 8 their M something, i forget. Thier out of production though. Trust be you will not be able to fit a 235 tire on your car. Im running 225/45/zr17's on mine and the tire it about a popsickle stick from hitting the strut. Gen 2's are lucky because they have larger fender wells then the Gen 1, so they can run 235's easily and 18 inch rims.
Dave Kegel
Chicago suburbs
I do, but they're kind of heavy for track wheels.
Dave
Dave Kegel
Chicago suburbs
IT-Purrrs said:
Kurt,
I run 235/45s on my Gen1 with 17x8" wheels. They fit fine. It's all in the offset. My wheels are 40mm offset. With the rear fenders trimmed I can even run a 5mm spacer in the rear with no rubbing.
Dave Kegel
jedhead
westminster,ca
I run 235/45 with 17X8 also. I did have to roll the rear fenders and trim a little bit of the plastic on the foward edge of the driver's side wheel well. I believe my offset is 35mm. I have plenty of clearance from the strut.
Bob
