14 sec. possible?
Corby
Porsche Eater
I was at the track last night and my first run was absolutely terrible. I was so dissapointed that I went and waited in line for another two hours. I was very impressed with my car, but again dissapointed in myself. The first run I was so worried I roasted the tires and this run I bogged it down alot. After looking at my timeslip, with a better launch and R/T I believe I can get 14.8 or so. Tell me what ya think:biggrin:
R/T .544
60' 2.745
330 6.904
1/8 10.273
MPH 72.36
1000 13.166
1/4 15.58
MPH 93.56
I know the R/T is terrible but this was my first time at the track and I wasn't aware you were suppost to gun it when you see the last yellow. I will be going to Byron raceway sometime.... I will post the numbers, hopefully I can get it into the 14's. All I have is a y pipe.
PAracer
West Chester, PA
Your trap speed shows that the car is making good power. I think that with a parfect run, you could get 14.8 out of it. The reaction time has nothing to do with the ET. You could wait another couple seconds to launch if you wanted to. If you drop half a second from the 60', you will have a 14 second car.
mosho93
Well-Known Member
Wausau, WI
Definately, get that awful 2.7 60' down to a 2.2-2.3 and you will be in the 14's easily as long as you dont miss a shift :)
Corby
Porsche Eater
Hehe, I know, it was my first time.... I bogged her down pretty good, better than roasting em like I did in the first run. I'll be heading out to byron sometime, hopefully I can get more runs in than two.
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
well according to this virtual engine calculator its saying you have 238 flywheel horsepower.... lol this dont mean shit but its kinda neat and fun to play with...
Area91 you have 393 flywheel horsepower according to this thing.. you should feel proud having almost 400 hp on a zex kit olny lol
by the way i put 3100 lbs gave the benifit of the doubt
Corby
Porsche Eater
How does that work?
SHOspazz92
Banned
Triad Area, North Carolina.
R/T .544
60' 2.745
330 6.904
1/8 10.273
MPH 72.36
1000 13.166
1/4 15.58
MPH 93.56
That 60' is awfull. Trying revving up to 3.5K or so and slip the living crap out of the clutch out of the hole. Its what I did and I pulled off a 2.31 60' on Used front tires and a Busted front motor mount. It may not be the healthiest thing for the clutch tho :smash:
And FYI Your R/T has absolutely nothing to do with your ET, Its that 60' thats killin ya!
-Sam
Corby
Porsche Eater
I thought once the light turned green the time started? What do you think I would run with a decent 60'
SHOspazz92
Banned
No, the time doesent start until your off the line. The only time a R/T matters is if your competitivly racing somone...wich I never do. You figure you have a 2.7 60' right now...get it down to a 2.2-2.3 You'd be good for a 15 flat/High 14 second pass, Easy.
-Sam
SideSHO09
Ca
so bad motor mounts do screw you off the line.
no wonder i havent done better than a 2.6 60'
RonPorter
SHO Club of America
Lake Orion, MI
Can't really tell. High 14s with a 2.1 - 2.2 60' time.
Go with 1500-2000 off the line, with a gentle clutch release. Keep the tires at normall preesure, lik ~35 psi.
Do a lot of runs. Practice makes perfect.
IMO, after 50+ practice runs, you will get there.
BlackonBlack89
burlington county,NJ
Good advice from my father.
Just act like ur at a stop light and wanna get ahead of the person. Dont drop the clutch. It rewarded me with 14.5@97+. Took about 7-9 times over 3 trips to the track. Practice is key, SHO's are not easy to launch
Sho Amo
SmkTyresntDrugs
Olney, Md
ive seen a 2.0 60 in my car before, wasnt my fastest e/t tho.
just remember that its front wheel drive. so when you dump the clutch all the weight lifts off the tires that matter unlike rwd.
Point is, be mindful of what you need to get the car going. This is why i use spring blocks.
somedude_001
Western NY
Or, you know, replace your motor mounts, which would be correct maintenance. Just sayin'.
last winter I installed shonut extreme mounts. I am not at all impressed. They are like jello. from day one they were never firm I felt like I wasted my money on them, and they were not exactly cheap.
32MTX
North Palm Beach
I wish I could find out what was done to my front mount, it looks like black silicone smeared all over it..... the sucker doesn't break
i even broke my rear mount at the dragstrip and the front one keeps ticking along, I've put it through years of daily abuse... wish I knew what it is that is on the mount as I'd like to do that to my other ones.
