Sho-Driver
Peter Pan
For quite some time now, I have been without dash lights. I originally checked the fuses and found nothing wrong. I rechecked today and found the #13, 5 ampere fuse burnt out. It will blow every time I turn on the head lights. Because I originally found nothing, I replaced the dimmer, headlight switch and relay.
I've tried to hunt down a grounded out wire, but I have not found anything yet.
To further elaborate into the story. I lost the dash lights while coming back from the store. They worked on the way there, then when I started the car to leave the store, they did not work. My aftermarket radio had been installed for quite sometime without any problems. I also have indiglo gauges, but they have been installed months before the dash lights went out.
If anyone knows any problem areas to check, help is appreciated.
TIA,
TIA,
