Leaking intercooler plastic pipe clamp
Bobg
Chicago suburb
Hi, ya know, im always on this site looking thru all the threads getting buttloads of info and using it, and my car and myself are loving it, I need to ask a question, I have a stock 2019 and its got 63k, my intercooler pipe plastic clamp between the throttle body and the map sensor is leaking oil on my valve cover. At first I thought it was a Crack in the valve cover, as I have a 2016 se with a leak in the corner. Its the plastic clamp. Its loaded with oil, even dripping underneath. I plan on getting different pipes soon, but in the meantime, can I slice the plastic clamp off and use a "Spectre Performance" 3" T clamp i picked up at Autozone? Or would it not be enough pressure or I accidentally Crack the plastic tube? Im super sorry that seemed to take me forever.
Bobg
Chicago suburb
Awesome! She was whining when I got off the gas at about 2-3k, the shifting in particular was alittle busy, plastic clamp was oily and oil blowby dripping from it, I cut it off with a mini hacksaw and put the t bolt clamp on, its like night and day! This car is literally, brand new! I can believe a tiny boost leak like that would give such a performance hit!
Bobg
Chicago suburb
I bought it with 40k and it always made a funny noise when I got off the gas, I cleaned everything, took off the blow off valves, shook them around and put them back, funny noise, just dissipated, but looking at the clamp, it was so bad, I cut it off, now it drives better than ever. Im at 63k
brainmax61
