Lower intercooler hose came off
jmstalke
My SHO is just a faster golf cart...
Michigan
So, I was changing my trans fluid and when I went to refill I noticed the lower intercooler pipe was crushed and the clamp had slipped off creating and air gap at the intercooler. I know the pictures are horrible but it's the best my phone would take. Car seems to run fine after I took the hose off, cleaned everything up and redid the clamps. Anyone know what type of damage could be lurking? Or if it runs good now am I in the clear?10000260281000026027
Majestic
I'd get rid of those worm-drive clamps and get some Breeze clamps. But otherwise, if the car is running fine and not throwing any codes, you are probably fine.
jmstalke
Michigan
I figured the EPP hot pipes kit I just bought from another member here would fix it up too I was worried about it causing damage to the turbo that wouldn't be obvious to a turbo newbie like me.
It is fine. The car will just feel down on power. You seemed to fix it. When you install the EEP kit, make sure the mating areas are clean, and I would spray the couplers with hairspray. The hairspray will be a lubricant at first, and when it dries it will lock the couplers and charge pipes together better.
Dang, that's a good idea... Thanks bro!
Also have fun with the rear coupler and installing it onto the rear turbo.
I suggest removing all extra wrenches from the area. You might be prone to getting upset and throwing them. I would suggest listening to music that will keep you calm and collected, and I would have a good strong drink before and after the rear coupler install.
With that, I wish you good luck.
jmstalke
Michigan
So it's a Jimmy Buffett plus a few Margaritas day drinking type of project... Noted. Thanks again for all of the advice/help. :)
hosbaldosho
