Will non-SHO Taurus headlights work on an SHO?
Joe_SHO
ND
I realize standard Taurus headlights don't have fishtanks, but will they fit or will they have a gap between the light and the grill? The tanks aren't important to me at all, and Taurus headlights are $30 vs $120 for SHO lights.
Racer X
SHO Pilot, Retired
Connecticut
No.
As an alternative to the $120 a side SHO-specific headlights, you can use the $30-$50 a side Mercury Sable headlights, and swap over your fishtanks. :thumb:
hawkeye18
Sorta cares
Norfolk, VA
QFT. I got two sable headlights for $64 shipped. I sprayed the headlights with a UV protectant clearcoat, swapped the fishtanks over, and it looks fantastic! And they won't yellow within a year.
hawkeye18
Sorta cares
Norfolk, VA
He means that if you purchase regular taurus headlights and put bulbs in them, then yes, they will shine and conduct light in an approximation of a good light pattern. They will not, however, come even slightly close to bolting up to the SHO.
Kens1992mtxSHO
The Commonwealth
What clear did you spray on them??
Storm-Chaser
Shit Louis
[____][] SHO
(____)_ non-SHO
You can always fit a round peg, into a square hole . . . .
Whether it "fits" also fails to take into account whether the lights will even mount properly against the header panel. So, . . .
Work? Yes. Fit? Yes. Fit properly? No. Look like shit? Yes.
Work? Yes. Fit? No. :p
cetroutt
troll
SEMO
i do believe that sable headlight and SHO headlights are the same, only sables don't have fishtanks. the problem with the SLO headlights on a SHO is the headlight mounting panel. they're not the same. plus the corners do not line up, not even close they stick out like a half inch further than the headlight. it is a sad and ugly problem i have with my SHO. PO put it in a ditch and did a hack job with the front end. i have a SLO nose and SHO everything else.
kevinspann
Don't take my advice.
Richmond VA
Theres a SHO with a SLO front end around my area. It also has a thunderbird airbag :(
