Atx Shifter **** Help???
brandon1186
ontario
I was taking apart my center console to clean it real good and i did not know how to remove the atx shifter **** so i turned it counterclockwise and that staple thing popped out so i pulled up on it and it came off but i broke the 2 white wires off inside the white plastic peace in the **** what are those for OD on and off? how can i fix this without cutting the leather open also whats the best way to put it back on :)
white93atx
pa
Try to repair those wires or get another shifter. Withot those wires you will drive around with your overdrive on all the time.
Or put a momentary contact switch on the console somewhere that you can use instead - the switch just needs to close so the pcm sees a closed circuit to switch between od on and od off.
projectSHO89
SHOless In St L
St. Louis, MO
Since that's the default anyway, what's the point (besides being able to kick it out of OD for fun)? The car will still drive fine in normal usage.
Steve
TopGunnYFZ
Livonia, MI
Steve
Exactly Mines been broken since ive got the car and i cant say ive ever needed it. It'll kick out on its own :salute:
SHOIT0ff
ontario
ok .....this will take some skill but if you do it this way they will not break for a long time. firsty, you will need to cleanly cut away at the lower rubber portion of the shifter. by doing this you will have access to the broken wires. Now, hold your shifter handle sidways so your broken wires are laying flat down and you can see them. I am assuming that the wires are so short that there is no wire to solder to, so if this is the case, take a marker and mark where the wires are within the plastic. i know its hard to see but you should be able to make out roughly where they go. by doing this you won't cut into them. take a rotory tool with a long thin bit and grind away the plastic about 1/2 inch up. remove as much of that plastic stuff as possible so that you will be able to lift up on those tiny wires and strip their insulation. the more plastic you remove the easier it will be to work on the wires. when you solder the existing wires to the thinker wires make sure that the solder joint is within the are that you ground out with your dremel. after you are happy with your soldering take a glue gun and glue in over top of the soldering job. by doing this you will protect the wires for moving and you now have thicker wires to deal with down below. thicker wires will not break so easily.
Now replace those crappy factory wires that sit below the console with somewhat thicker wires. to do this simply cut the connector off 1/2 inch above the harness, so that you can strip the insulation off and solder the thinker wire to the thin one. Solder the two together and again, use a glue gun to cover and strengthen the soldering job. remember that the weakest point on that connector is the thin wire that enters the harness. by gluing that entire area you are restricting it from bending a million times. just like they do to keep the end of head phone jacks from breaking. hope this helps its very easy but sounds hard. i did it three years ago and have had no problems since.
cobrakidd03
michigan
Mine is also broken, but I only have one wire comming out of the shifter handle. Is that right?
SHOIT0ff
ontario
no there should be two. but it may appear to be one wire due to a shielding wrapped around the two.
brandon1186
ontario
thanks for all the replies what did was i had a old car alarm laying around so i took the toggle switch from the alarm and hooked it up to the od wires cut a hole in the center console on the carpet and mounted the switch there works like a charm
