My left foglight keeps blowing out...
ScottyDsntKno
NJ
In an attempt to get my SHO as good as it can be since I finally got it back on the road I'd like to get my fogs working properly. The right fog is completely fine, always works. The left one has about 5 minutes on a new bulb before it blows out if left on. This is, luckily, enough to get me through inspection but I'd like for it to work. To me this sounds like a short somewhere but I'm really bad with wiring. Where is the first place I should look for something like this and how much of a PITA is this going to be?
Also is there a way to just bug the entire foglight harness right into the fuse box and just run it through the stock switch like an aftermarket unit? I'm guessing this would probably be the easiest.
