seafoam
guitar
MN
I was thinking about giving seafoam a try on my car to see if i could get any results, but what is the best vacuum line to use? I dont have any extra vacuum line laying around so id just like to know what one i can disconnect and use instead of going out and buying some extra line.
-DVP-
NaNaaNaNAAAA!!!
0 .· ` ' / ·. Full Retard
Im not sure on SHOs but on my Cougar people use the Vac line that connects to the brake booster.
jthod
Mr. Goodwrench
Lincoln, Nebraska
there's a line that goes into the drives side of the intake, a little ways past the throttle IIRC. I havn't done it in a while. Maybe the breather line from the valve cover???
Kens1992mtxSHO
The Commonwealth
On top of the intake manifold behind the throttle body is a vacuum hose. Disconnect that one from the manifold and you will hear the suction. FWIW I have seen better results with BG's throttle body and intake cleaner than with seafoam.
