subframe bolts
PFA
MI
I am having an issue with a couple of bolts acting like they are cross threading. Anyone have this? Is there some kind of fix? What should I do? Any ideas?
Thanks
stephen newberg
Ladysmith, BC, Canada
There is no easy out on cross threaded and/or rust welded in bolts in the subframe that I know of. You do what you would for any bolt under those circumstances. Heat, shock (hammer), etc., and hope it comes out without snapping. If it snaps, you drill.
pax, smn
  • Like
Reactions: PFA
PFA
MI
pax, smn
Thanks. What I was doing was putting them in. I ended up switching the bot twice with one of the others and it finally took. I was getting nervous for a while....
They are cheap enough it's a good idea to buy new ones.
N804442-S426
PFA
MI
N804442-S426
I assume still a dealer item? I will check into them. I got everything together today. Need to fill fluids now, test and install front bumber.
shobroooo
