A new victim to the Sho...
Kilty423
Sho-fer
Pennsylvania
I have a 1993 mtx sho. Well on my break from work i just got out of a wendy's. I pull out in 1st gear and i took her to 5k. I shifted into 2nd lost power and finally she stalled. I am thinking the crank sensor. She wont start back up either. Whats all your opinions? Any insight would be appreciated.
shoon
cliTaurus
Dawson Creek, BC
Any trouble codes?
Does the water pump leak, is there loss of coolant?
does the tach move when you crank the engine?
Racer X
SHO Pilot, Retired
Connecticut
Check the connections on the DIS. Bad retaining clips + weak motor mounts + hard shift = 4 way flashers on the shoulder because you yanked the connector out of the DIS.
Timing belt broke
Or
Subframe dropped and disconnected DIS
Or
Crank Sensor
Three things that come to mind right away...
SuperHO
Mental Patient
St. Joe, MI
Both of those are good answers for you to start with. Another thing to do is when you're sittin in the car, preferably at a quiet moment, cycle the key to the "on" position (just before you start it) and leave it there for a moment. You should hear your fuel pump whine. If not, there you go.
But I'd lean more towards a crank sensor being the likely culprit. Like what's-his-name said, watch the tach needle when you're cranking it. If it don't budge, you just bought yourself a front 60k.
Kilty423
Sho-fer
Pennsylvania
Thanks guys. The tach does move. My buddy on the forum told me the same stuff. Could also be a bad ground somewhere. Anyway he is sending me a DIS and a coil pack just in case. I am gonna try that first.
SuperHO
Mental Patient
St. Joe, MI
any fuel pump noises? ****, any fuel pressure at the rail? Take the cap off that schrader valve in the middle of your intake and stick a pen in there while a buddy hit's the key...
RAYJAY
WHO ME ?
UNION DALE PA
parts are on the way
Jeff
Kilty423
Sho-fer
Pennsylvania
Actually guys..i think its the fuel pump. It will not make the whining priming noise when you first turn the ignition on.
Make sure there is power to the pump.
There is a bundle of wires running down the drivers side of the car, to the left of the drivers seat, under the carpet. All you need is a phillips head screwdriver to remove the trim, then peel back the carpet.
The connectors get very corroded and eventually fail. The fuel pump is on a black heavier guage wire with a white stripe.
While you are in there, you can put a volt meter on that lead and make sure that when you turn on the key, you get 13 or so volts.
the other black wire is for the powerlocks and the seats, they are in separate bundles.
expy916
sacramento
Fuel pumps dying on a SHO suck! Had to push the SHO for a whole mile to the nearest parking lot.
Kilty423
Sho-fer
Pennsylvania
I feel your pain when mine died i got lucky and had space to pull off the side of the road and had to wait for a tow truck.
SuperHO
Mental Patient
St. Joe, MI
what's worse is the week after doing a fuel pump, sitting in the staging lanes at the local 1/4 track, and getting yelled at to shut it down cuz you're leakin fuel all over the place.....made it almost home before I ran out of gas. Walked 4 miles to the house and the next day drove out, dropped the tank (on the side of the freeway off ramp) and found the fuel return line had popped off thanks to a broken plastic clip.
Speakin of which, when you replace the pump (i recommend the Walbro 155lph), make sure you replace the rubber gasket between the tank and the pickup, and the lil plastic clips that hold the fuel lines in place.
