shoff89
Went to the track yesterday and I guess I pulled 2nd so hard it ripped the bar out of the tranny. Is it possible to weld this or do I ned a new tranny??:thankyou:
Need a new transmission, it sounds like your diff pin vented itself through the case
If the pin came out would the car still be able to move I drove it over 40 miles home. no weird noises
yup, some guys have driven up to 1000 miles with blown diff's.
Yes I lost fluid and the piece that broke of is still attached to the bar
Find someone experienced with welding aluminum as it requires some special effort and skill.
Did you actually lose fluid, or did you just rip the boss out? From what it sounds like, you just ripped the boss out in which case someone used to make a boss brace which might be able to fix your problem. Going to have to search.
When I was attempting to show off for a couple of mullet-headed buffoons who swapped a non-turbo 2.2 into a Shelby Z, I snapped my boss. The guy who fixed it just fabbed up a bracket to use one of the other holes in that region, and it worked fine until I grenaded a diff pin almost 2 years later and who knows how many drag passes/broken motor mount bolts/burnouts?A few posters seem confused about what happened. He broke the shifter stabilizer rod off at the case. He did not blow the diff pins. The previous suggestions are good ones. Tig weld it. Beef up motor mounts so as not to repeat. You will also notice the transmission has several handy unused holes in the general area. You can fabricate a bracket secured to those holes to support the shift rod. The bolt that secures the stabilizer cannot, of course, use the full thread depth in the boss. I think it would be a good mod to replace the bolt with a stud, which could be threaded all the way to the bottom.
Thanx. I will go that route. didnt really want to spend the money buying another trans when mine is fine and labor FTL. And the motor mounts now that I think about it are horrible. We used to have a shop around here called protech that did the reinforced on my 89 but hes out of bizzness and no one else wants to do the job. Will the welder need to have the tranny out to perform the job or no?
