Silver fluid leaking from trans?
York Haven, PA
I just noticed this today - there is a silver fluid leaking from my transmission/rod shifer connection area - or thats where I think see it... car smells like it's burning somthing as well when you shut it off- almost smells like hot brakes. I have no idea nd I can't seem to pick out this smell... please help! Any info would be great!
it's a 94 MTX 100k on it.
AREA 91
Area 91
Silver? I hope that's just dirty ATF.
There is a shift shaft seal that resides under the rubber dust boot. You can replace this with the car on jack stands. If I remember right, you din't need to drain any fluid either.
Also check the seals where the CV shaft slides in. Felpro 3622
shopartsnw
SHO Medic
Battle Ground, WA
I agree with Area91 on the shift shaft seal. It is super easy to replace.
Silver fluid is a new one on me. It should be pink or red since it is ATF.
I can explain the smell. If the fluid is not changed often enough, it gets a smell I most compare to burned gunpowder. I highly recomend changing your fluid, as it probably needs it. Try to collect the fluid in a clean container so you can see if the "silver" is from metal flakes in the dirty fluid.
Mike
itwonder
VA
Hmmm, silver fluid is fluid with fine metal particles suspended in it. I would drain the transmission fluid asap and inspect. Install a drain plug if yours does not already have one.
