Itching to get started!
Brett
SHOs before HOs
Minnesnowta
Getting all this stuff in the mail really makes me want to tear into the SHO. Then i look at the snowbank its in. :nut: Can't wait for spring.
Specs stage 3 clutch
PICT1552
PICT1554
SHO NUT ceramic TOB
PICT1545
top and front 60k, minus CPS and rod bearings, and plug wires all in the mail.
PICT1555
SuperSho92
Cincinnati,Oh
I know what you mean...I have:
Front and rear strut tower bars
GC Coil Overs
96 Brake Upgrade
SS Brake Lines
Jose short shifter
Custom aux gauge set up
Tape/CD combo
waiting for me...and I just started collecting parts for my 3.2 build as well.
whiteman_01
Well-Known Member
Hastings, MN
Seeing all the rust coming through on my 92 really makes me want to get rid of it. But, there will be a replacment. I am looking for somthing with a little more cargo room. :evilgrin:
SHOguy 92
Duluth, MN
I've seen your cousin around a few times and he was telling me about your car. Something about machine shops not wanting to put the motor back together or some BS.
Phoenix
SHOHOLIC
QC , Canada
For me , im getting back in it to fix my white's reverse in the easter week. I also got Accel coil to install.
After that it'll be ready for a dyno run. Can't wait , I know too much what you mean...
Brett
SHOs before HOs
Minnesnowta
Well that itch turned into a scratch. Went out back to dig the SHO out and much to my surprise it wasn't buried, relatively snow free, actually.
PICT1572 1
PICT1576 1
PICT1575 1
I ran a trickle charger to the back yard and hooked it up, listened to the cd player and even started the car. Fired right up, once the battery was charged. Sounded to be running good, good throttle response... Then a bunch of smoke from under the hood, one of the belts snapped so i shut it off lol. the chatter from inside the bellhousing was still there.
I then went ahead and pulled all the seats, misc trim pieces and hopefully the dash and center console in the near future. Im going to give it a thorough cleaning, maybe even a new drivers seat if i can find one around here. The carpet is trashed, battery acid got into it behind the driver seat somehow and its all chewed up. Anyone ever replaced their carpeting before? Did you use a roll or specific cut carpet to our cars? I'll post pics when i get home, its pretty ruff. I've come to find plastic is quite bridle in the cold. Anyone know wheres theres a gray interior parts SHO around? :nut:
PICT1577
PICT1578
PICT1579
Almost embarrassed of how nasty it is. But i assure you it came in worse shape, 3 + years with the sunroof cracked = alot of pine needles and leaves.
Good below freezing times.
PICT1582 1
Ever happen to your dash? Not so cool. Anyone have any fixes? Thanks.
PICT1580 1
First couple wouldn't put the rolling assembly back in the block period. Mostly because i disassembled it myself, which was probably a bad move but i wanted to see how it all went together.
Another guy would but only if he could order new pistons for it, which he quoted to be more then some nice wisecos of my compression choice(1000 for pistons alone). To be honest i probably could have had the 3.2 together and in the SHO by summer. But not the way i wanted it. its been all cleaned up, I have the new rings and bearings etc, but I really want brand new thrust bearings, some head work, intake porting etc. maybe even some wisecos (i just felt my wallet wrinkle). The 3.2 will stay on the engine stand for now. unless i could find another 3.2 dirty cheap to throw all my 3.0 stuff on while its all out for the clutch job :nut:.
In the mean time ive ordered everything needed for a full front and top 60k, rod bearings and other misc things for the 3.0.
Ive been driving a slush box, soft suspension, huge front end GM car, all winter and im so sick of it. Its a coupe none the less. Most would take the eldo over the SHO but to me its no contest, i love my taurus. I'm not gonna lie, ive been waiting to see your dyno numbers for a long, long time now. You have a pretty balls out NA build. Dyno charts are Long, long overdue. :evilgrin:
Brett
SHOs before HOs
Minnesnowta
makes me want a stage three clutch. good luck.
btw your front wheel is dicing
-Dan
the clutch is a bit overkill at this point. But S3 with the ceramic shonut TOB im hoping it'll last awhile, awhile meaning when its time for the 3.2 to go in with a shot. In a way its better to keep the 3.0 at this point, it'll give me the opportunity to find out if the bottle is really for me before i dedicate a 3.2 to it.
pfcusher
Duluth, MN
Hey man im gonna be taking leave from April 12-22 (for your 21st) and maybe we can get the short block together and ill let you play with the heads and accessories once im gone :) Honestly, once you get all the stuff shouldnt take us more than a night to get it all together.
Brett
SHOs before HOs
Minnesnowta
IF it were up to me id need alot of things, but mainly carpet, the plastic around the bottom of the drivers seat, the driver seat itself (if anyone finds a parts car with a good drivers seat in gray let me know) and a wheel. Probably a couple more little things, ill let you guys know.
BTW got the new clutch disk back and all is well. Can't wait to get it started.
crystizel
