new ccrm but blower motor and fans still stay on
tavius
arizona
I recent replaced the crankshaft pos switch since the sho wouldn't start, at the same time the cars blower motor and rad fan would not turn off so i replace the ccrm with a new one, but the fan still stay on and the car won't start it turns over. what could be causing this?
shopartsnw
SHO Medic
Battle Ground, WA
I see you are posting in the V8 section, so I just want to make sure you are talking about a 96-99 V8 SHO.
Which CCRM did you install? There is a large letter on top of the CCRM label (like a big R).
Mike
tavius
arizona
the part number is 430 rcm12 from rockauto.com. The new ccrm appears to be a lot lighter than my old one. Do you think i have the wrong module? how do i verify this?
Mr Anonymous
Tire Wall
St. Louis, MO
Your CCRM is fine, your problem is the PCM has no power, which also explains your no-start condition.
The fans default to on when the key is turned to run but there is no PCM power.
Any chance you have a chip installed?
tavius
arizona
no i have not had a chip installed. Could my pcm be bad? How do i fix this problem?
Is there a Ford part number or a large red letter on it?
tavius
arizona
well the pcm verison number is AWL1
the ccrm has a big R on it and the part number on it states: f6sf-12b577-aa
You need to check for 5V+ at the TPS when the key is on. This will confirm if the PCM is getting power or not.
If the PCM is not getting power then you need to check the red wire coming out of the CCRM for 12V +. This is the PCM power.
Yes, one wire is 5V, one is ground and one is the voltage back to the PCM.
I use a small solid copper wire like that found in fluorescent fixtures to backprobe the TPS connector.
tavius
arizona
when i use the battery as a ground I get 8.3/8.5/8.9 volts at the TPS, when i use the ground at the TPS I get no voltage at either of the other 2(terminals in the TPS connectors)
I also measured the voltage at the ccrm it got 11.76 with the key in the on
where should go from here?
The PCM should be putting out 5V regulated power. I would disconnect the battery, disconnect the PCM connector, reconnect the battery and remeasure the TPS voltage. There should be none. If there is none then I would suspect the PCM is bad.
tavius
arizona
well with the pcm disconnected and the key in the on pos. I got 0.67 volts from the TPS, So is it safe to say that my pcm is bad? Do I have to get the same verison for the pcm as a replacement? for instance my pcm is a AWL1 can I use a AWL2?
Mr Anonymous
Tire Wall
St. Louis, MO
Just for giggles, pull the PCM out and see if perhaps there is a chip installed that you don't know about. A chip getting dislodged can cause all sorts of problems like what you're seeing. There are two 11mm nuts holding the cover in place that secures the PCM.
Any 96 or 97 SHO PCM will work, JJKx, AWLx, LBLx, etc. Paul probably has the whole list of catch codes more readily available than I do.
There shouldn't be any voltage if the PCM is disconnected. Don't know how accurate the voltmeter you are using is.
You may have a ground problem somewhere.
