Turbo project progress pics(rough).
DVJ38
Hartford, CT and Worc, MA
I am a clutches worst enemy... Boost is my new weapon of choice:scared:
I still have a perfectly good CM1 PP(disc broke). Maybe they can sell me the disc alone.
And Tom, uhhh... Ok, ya got me there:asskick:
HAHA nice Nick. I think your trap speed will be close to Toms' trap but your ET won't be as low lol. Worn out BFG's FTL haha.
Just make sure to let that punk clutch know who's boss. :evilgrin:
jthod
Mr. Goodwrench
Lincoln, Nebraska
Nik, this guy sez you need more turbos...
Incin9
Eek5jerk
Question is: WHAT IS IT?????
check out the website on the bottom of the picture on the car. Talk about sweet cars!!
I'm still trying to find out what that engine is in.
yamahaSHO
E85 whore
Arkansas
Awwweee... You too?! That's it, I'm going NA!
JK! It looks like a decent setup. Watch your oil temps with both those hot exhaust pipes running under the pan. I noticed a difference in temps with just the SHO SHOP "equal length" y-pipe since the front pipe runs near the oil pan as well. I've been thinking of heat wrapping my entire y-pipe.
nik97
Mile high
Eek5jerk
It's in a '57 Chevy I believe. 8 turbos each pushing 2 psi and I think they call it the INCINER8OR. Cool but pointless for 16 psi accumulative.
nik97
Mile high
I am going to have the hot pipes Jet Hot coated but may also wrap them around the pan. Should look nice at least;).
Finished the IC tonight...
Turbo3007
Turbo3009
Yes I know my tires are backwards. I threw them on in a hurry:nut:
Some more duct tape for yall:cool:.
jthod
Mr. Goodwrench
Lincoln, Nebraska
Next up:
Powdercoating?
black and silver looks badass on a white car.:evilgrin:
I'll post a better pic, but the sig shows it pretty well.
somedude_001
Western NY
SHO's look so bad ass with a front mount. keep up the good work. It looks like you should be running soon.
BlackonBlack89
burlington county,NJ
That looks sick. The intercooler looks right at home sitting there. Get that thing running:thumb:
What size piping did you go with??? Is it 2" or 2.5"???
nik97
Mile high
gmorrell
Never been a noob...
Colorado Springs, CO
It's in a '57 Chevy I believe. 8 turbos each pushing 2 psi and I think they call it the ELIMIN8OR. Cool but pointless for 16 psi accumulative.
I agree: Pretty plumbing, absolutely stunning fabrication, but those turbos won't spool for sh*t.
Shoaz
Studly dood
Scottsdale, AZ
Definitely a lot of nice show muscle cars. It cracks me up that they pick a name like "lateral-g" that implies handling. :p
Yeah, that's gonna happen. :rolleyes:
I've no personal experience with it, but have always heard that a downside of wrapping is accelerated corrosion. Don't know whether that would be true with a coating like jet-hot, as the corrosion issues were usually with light-weight race applications before coating became popular.
And it's lookin' good, Nik. Are you keeping track of the $$ you're spending? I'm guessing you're going to be a contender for one of the lower-cost full turbo installs.
Toolman
Boost it!
Grand Lake, Oklahoma, USA
Looking good nik! One word of caution, with all those connections, take car to keep those pipes secured well, as the bouncing around and vibration could lead to a blow off at a connection. Are the pipes beaded at the ends?
Toolman
Boost it!
If you approach wrapping with the idea that you need to replace it every year (or sooner depending on driving conditions), then corrosion becomes much less an issue. Also ,the wrap will trap small particles which become like little sandblasters over time. Not driving in the rain or on dirty roads will help a lot as well. Coated pipes will certainly withstand the abuse for longer, you should install new wrap on the same schedule as a non-coated pipe. On my car, only the up and downpipe are wrapped. Due to the location of the y-pipe, that wrap would get contaminated quickly, and you would likely need to change it often.
F-22 Raptor SHO
7015 feet above Sea Level
but he has that badass duct tape holding it up...thats good for 200 mph.
nik97
Mile high
Well, took it for a spin to allow any "issues" to arise(and they did.) I put the turbo's regular waste gate back on with an adjustable rod(adjusts from practically zero boost to way more than enough). I have not cranked it and smashed on it yet since I have no idea what the AFR is but I can tell from driving it that I wont likely have turbo/pipe sizing issues. If I had to guess, I'd say the WG is set around 3 psi right now -a load of TQ comes at around 3000RPM and shortly thereafter, I hear the the WG opening(@ 50-75% throttle). It feels awesome and it is very tempting to see what it's got but not without watching the vitals. Also another thing I noticed was that is does not want to cruise at all. Any sustained part throttle causes RPM fluctuation and it wants do stall on decel sometimes.
Now that the "work" is done, I have to save for the pricey but required equipment. I cant wait to get this thing dialed in!!!
