Opened drivers door from inside and..... craaaackalac
CPUNeck
Glow-plug Detox
RSA, AL
Well something broke in the latch mechanism. The door still opens from the inside, but the handle is loose and doesn't retract the way it did. Am I just going to have to take it apart to diagnose, or is there some "part" thing that fails on these? TIA
jelloslug
Digital
Greenville, SC
The arm on the inside of the handle broke off. Most parts stores should stock the drivers side handle. You will have to drill out the big rivets to get the old handle out.
SHOtimer
#2910
Santa Clarita, Ca
Mine broke about a year or two ago. Just had to roll down the window to get out for a few days. A cheap part and a few hours later - works great!
Doug
StockersAuto
Rocket Powered
Duluth, Minnesota
Well something broke in the latch mechanism. The door still opens from the inside, but the handle is loose and doesn't retract the way it did. Am I just going to have to take it apart to diagnose, or is there something "part" that fails on these? TIA
The spring that retracts the handle broke. Same thing happened to mine. Opened the door and I heard it break. Boy, was I relieved when the handle still worked and I found a piece of the spring.
I never fixed it though. Didn't feel like ripping another door panel off. Car died a month later anyway.
SHOMON
95 MTX
MEDWAY MASS.
If you do get a replacement handle say at the bone yard
use the one from the rear door. It will last a little longer before breaking because it has been used less.
shobroooo
