My SHO engine was completely drained of oil this Summer; oil pan off, oil pump off, oil filter off. When I refilled it with 5 qts. after reassembly (and before starting it) I noticed the oil level was right at the full mark on the dipstick. I had expected it to indicate about 0.5 qts over full until I started it up and pumped some oil up into the filter and other nooks. That's because the engine oil capacity specifications are 5.0 qts with filter, and 4.5 qts without filter. If Ford expects 0.5 qts. to be contained in the filter and other nooks up in the engine, then wouldn't the dipstick need to show full with 4.5 qts in the pan to be consistent with those specifications?
Editing this for future reference -- Answered my own question. Dipstick showing full with 5 qts in the pan is correct. Why? I found a service reference, see post 15 below, that gives a "dry fill" specification of 6.0 qts. That tells me 1/2 qt. lives in the oil filter, and 1/2 quart lives in the nooks and crannies of the engine, leaving 5 qts. in the pan. First time I've seen this 6.0 qt. spec.
