Valve Guides
I am getting my heads ready for the 3.2 swap. I noticed a few threads relating to the valve guides. Most thread say not to worry about them.
Should I get them replaced when I have the heads cleaned? Could they simply be knurled(as opposed to replaced)?
Edit: the heads have less than 150k and the engine ran fairly clean(little or no oil burning)
I will be replacing the seals. Should I "replace the valve stem seals and call it a day"?
'94SHO
Towley rules!!
R.I.
Knurling the guides is a temporary fix. If the guides are out of spec., I would suggest replacing them; with phosphor/bronze guides. It is easy to do.
You can either ream them or press them out , and replace the guides. OR, ream the guides,
and use slightly oversize (stem) valves. I believe you can get a reamer,and valves in
.001-.002 oversize.. For most engines, anyway. This is cheaper, and longer lasting than knurling.. (My instructors were pretty clear on this).:thumb:
Whassup PHX.!! A.T.I rules!! 44th ave. and Camelback!!
revhardSHO
Seattle, WA
Yeah if you are going to have the heads out, its a really good idea to replace the valve guide seals. The time is now!
