roswell998
I have some slight pinging especially at slow speeds under light load both when cold and when at operating temp, however it is somewhat worse when cold.
I have an Actron CP9190 scanner so what is the best way to test the KS?
Both KOEO and KOER tests are 111. Cylinder balance test passed.
I read somewhere (perhaps on this forum but I can't find the thread now) that placing a socket extension near the sensor and tapping it lightly with a hammer should generate a knock signal, but how would you detect that signal? If the engine is running, would that generate a code?
Help will be appreciated
