fitting 2005 GT shift **** to my 91'
DJSHO91
Durham, NC
I have been trying to fit a 2005 Mustang shift ****2601643988498080 1 to my 91' SHO. I remember seeing one added previously, but nothing showed up on my search. Can anyone help me with how to do this? I also have the problem of the shift boot breaking away from console(tabs all broken). Any ideas if this can be repaired? Thanks for the help.
whiteman_01
Well-Known Member
Hastings, MN
In order to make it fit, you have to open up the whole on the **** a bit. I just used a file in order to do it. That way it will fit over the main part of the shift shaft.
As for the broken tabs, i epoxyd 4 small threaded rods to the bottom of the counsel. I then drilled 4 holes in the metal trim ring, and secured it with nuts.
VADERSHO
C-DAWG
Tulsa,Oklahoma
So will this **** not just screw right on? I just bought one on ebay and waiting for it to come in.
plethaus
Kittyland Love Center
He said that it will screw right on, you just have to make the hole on the botton of the new shift **** bigger so that it slides over the shaft.
Huh huh huh, I said shaft.
0V3RC10CK3D
Washington
No, it won't fit by itself, you need to get the hole drilled bigger down to the threads.
Mine
DJSHO91
Durham, NC
How did you drill it? What size bit did you use? Do I have to drill out the threads and re-tap it? I appreciate your help. Your original pics were what made me pick this shift ****.
Mine
0V3RC10CK3D
Washington
I took it to a machine shop and they drilled it for free, the threads are a perfect fit but there is a lip on the shifter just below the threads that wont fit inside the ****, so you need to drill the hole bigger down *to* the threads inside the **** so that you can screw it on.
whiteman_01
Well-Known Member
Hastings, MN
There are actually no threads in this ****. It just has a plastic core, and makes its own threads as you put it on. It took me all of 5 min. in order to get mine to fit.
Shifter002
Phoenix
SHOHOLIC
QC , Canada
I took my die-grinder with a carbide porting bit to do it , no specific size , the base just needs to be bigger a tad.
whiteman_01
Well-Known Member
Hastings, MN
If a stock **** will, then i would think so. Is the main shaft on the SHOrt shifter larger than the threaded part?
0V3RC10CK3D
Washington
I'm pretty sure there are threads in it, i took a light to it and saw metal down in there, also it would strip it out with how tight i put the **** on there if it was plastic.
whiteman_01
Well-Known Member
Hastings, MN
When my brother installed the one on his car, he also cut the threads on the rod way down. He had to drill out the entire shifter in order to get it to fit. Never hit any metal, but i guess ours could be different.
DJSHO91
Durham, NC
I just wanted to say thank you for everyones help. It fits and feels great.
Thanks for all the help.:thankyou:
