aarmel732
Hey, small problem with a car the PO said was "mechanically perfect". The A/C does not work at all. We hooked up a can of referigerant to the low side and the gauge went all the way around to the stop. The A/C shop says it is a wiring problem. The fuse is ok. The compressor does not even kick on at all. Could this be a football, compressor pressure switches, or just plane overcharged? Where do I start? Thank you guys so much, you guys are the masters at this. I am looking forward to my SHO ownership, but it sure is hot right now! Also, is it possible to remove the automatic climate control and convert to the radial dials?
