shokid20
is there a difference between the injectors and if so what ones has higher psi
3.0 injectors are pink and flow 23.7
3.2 injectors are purple and flow 24.4
You are looking at a 5-8 crank HP difference.
BTW I dyno'd 257 Wheel HP on 3.0 injectors.
To add to the above, neither have a "higher PSI". Both are regulated the same. The injector offset (programmed into the ECU) is what makes the larger injectors work properly with with the same slope (also in the ECU). If you have a 3.0L harness/computer, just stick with your 3.0L injectors.
No gain it to be had.my fuel rails are out for clean/paint & upper 60K so I was just going to install the 3.2 injectors I have with the new 'O'ring kit. So its a stock 91+ with 100K & you are saying I will see no benifit at all! Will it be a deterent/loss of anything? There will be no chip in it now as LMP's are worthless as no one will flash them!
thanks guys i put the 3.0 injectors in. oh and how much hp is the 3.2 with 3.0 cams, like when the swap is all done and dynoed what would it be?
