MTX gaskets
Cocoa,Florida
im doing a clutch job in my 91 soon and ive got a few questions.
the transmission is leaking fluid from an unknown seal.
so while i have it out,id like to go ahead and replace all the gaskets
from what i understand theres 4 right? input shaft seal,2 axle seals,and the shifter shaft seal or what ever you call it??
can these seals be instaled by myself easily or should i drop the trans. at a shop and have them do it??
You will have tranny out for clutch install?
Do them yourself.
Maybe PM Bizzy to see if there are any gotchas.
Phoenix
SHOHOLIC
QC , Canada
Yes but remember the 2 halves of the tranny (between) might leak too. So it's a 5th place it could leak.
masho95
got Zex?
Chicopee, MA
SHOtime2511 said:
is there a seal there too?
No the two case halves are sealed with anaerobic gasket maker.
sho_sc
Georgetown, KY
Unless the tranny has been apart, IMHO, there is a 95% chance that the axle seals are the problem. Sometimes the input shaft seal (speedo sensor) will leak due to the shaft vibrating itself loose.
Racer X
SHO Pilot, Retired
Connecticut
Where the **** do you buy this stuff???!! I was at 8 parts stores here in queens, and not a one had this stuff. My tranny is out, and I wanted to replace the tension pins in the diff (the diff pins have some axial play that I'm not especially enthusiased about :omg: ).
Mr Anonymous
Tire Wall
St. Louis, MO
NAPA (or Naperrr as some locals call it).
jedhead
westminster,ca
I had to order on line.
Bob
tinkerkathleen
